3.7 update procedure for dummies
StephenSmiley777
- Backup your Helix. Do it now (I know, the update instructions will tell you to install the new HX Edit first, but you have a working system now, so this is when you do a backup).
- Log into your account within HX Edit (in case you haven't done so yet). You should see an update available notification (lower right corner or a popup).
- Accept the update and follow all further instructions.
- Make sure to do a factory reset.
- When done, reload your backup.
- Make sure to reboot after that, so the Helix can rebuild your old presets.
On 11/17/2023 at 11:14 PM, StephenSmiley777 said:
How to properly update to 3.7 without losing all my custom presets in my non factory user 1-5 ? Im confused by the instructions regarding this. Please help!!!
The info supplied by @SaschaFranck is correct, especially about making the backup first before installing HX Edit.
I have also replied to similar post earlier that you might want to check out here:
Hope this helps/makes sense.
