urklvt Posted November 18, 2023 Share Posted November 18, 2023 I read through the manual and it didn’t mention that the unit is able to send midi data. I was hoping to have some limited Command Center capability so that I could send PC/CC info when I press either of the two switches. I don’t really need the flux to be able to control external devices even though that would be awesome. My main hope was to use the unit as a poly capo box and send CC info to my guitar synth to enable its alternate tunings when I turn the effect on. I currently have that working on the Stomp but I was hoping to take the capo effect off of the stomp to give it more resources. I know I could put the One after the Stomp but I was hoping to not have to. Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 18, 2023 Share Posted November 18, 2023 The full MIDI capabilities of the HX One are described in the manual. Specifically it states this: HX One does not transmit MIDI for any of its own actions, but will pass incoming MIDI control and MIDI Clock out via its MIDI OUT/THRU and USB MIDI ports. There is no Command Center, or any other capability to send MIDI on its own. 1 Quote Link to comment Share on other sites More sharing options...
chitounet Posted December 23, 2023 Share Posted December 23, 2023 I would have liked that it can at least manage Tx clock like on the hx stomp. This way, I can use it as clock master using tap temp footswitch :( i don’t know if it a hardware limitation … hope line 6 can add it soon … Quote Link to comment Share on other sites More sharing options...
