HX One Midi Capabilities
urklvt
I read through the manual and it didn’t mention that the unit is able to send midi data. I was hoping to have some limited Command Center capability so that I could send PC/CC info when I press either of the two switches. I don’t really need the flux to be able to control external devices even though that would be awesome. My main hope was to use the unit as a poly capo box and send CC info to my guitar synth to enable its alternate tunings when I turn the effect on. I currently have that working on the Stomp but I was hoping to take the capo effect off of the stomp to give it more resources. I know I could put the One after the Stomp but I was hoping to not have to.
The full MIDI capabilities of the HX One are described in the manual. Specifically it states this:
HX One does not transmit MIDI for any of its own actions, but will pass incoming MIDI control and MIDI Clock out via its MIDI OUT/THRU and USB MIDI ports.
There is no Command Center, or any other capability to send MIDI on its own.
  • Thanks 1
  • 1 month later...
