Copy Paste Helix Edit <> Helix Native
markwesse
On 11/23/2023 at 2:52 AM, markwesse said:
Shouldn't this work?
ie Right click copy/HX Edit
Right click paste/HX Native
Drag and drop works fine.
From the Helix Native Pilot’s Guide:
NOTE: Copy and Paste of presets and IRs between Helix Native and HX Edit is not currently supported. However, you can use drag and drop for these actions!
  • Import - Drag any saved .hlx Helix preset file from your computer’s hard drive and drop it directly into a slot within the plugin’s Presets panel to import it into the Presets Library. (Note that this does not automatically load the preset as the current tone in the plugin. Double-click the preset slot you imported into to load the preset.)
  • Load - Drag any saved .hlx Helix preset file from your computer’s hard drive and drop it within the plugin’s Signal Flow window to load it.
Hope this helps/makes sense.
To add to datacommando's post: Copy/paste only works for individual blocks. But in case all you want is to exchange things between Edit and Native, drag and drop is faster anyway, simply because all you have to do is drag things around (and possibly tab between windows with your other hand).
