Kingbrit Posted December 6, 2023 Share Posted December 6, 2023 Anyone else have issues where their tuner doesn’t do anything? Even if my bass is plugged in direct to the HX One it does nothing. Doesn’t mute even though it’s set to mute. effects work as expected so the signal is going in ok just the tuner doesn’t. Makes no different which input I use.. factory reset didn’t fix it.. Quote Link to comment Share on other sites More sharing options...
juecker Posted December 7, 2023 Share Posted December 7, 2023 Are you running in True Bypass mode, by any chance? One of the "known issues" in the current firmware is that the tuner doesn't work if you aren't in DSP mode. I'm not sure if that's a limitation of the pedal's architecture or something they plan to correct down the road...hopefully the latter! :) Quote Link to comment Share on other sites More sharing options...
jmay214 Posted December 7, 2023 Share Posted December 7, 2023 I am using the HX One in Insert mode, and all signal paths work just fine except for tuner. I don't think I'll ever have a need to use that tuner, but I can confirm it isn't working for me either. Also had an issue with Midi Thru not working, but that would be another issue. I swapped things around to make it the last in my chain until it gets fixed. Quote Link to comment Share on other sites More sharing options...
