jankoraseta Posted December 29, 2023 Share Posted December 29, 2023 Please, please add a mode that will show the Preset Name instead of name of the effect. I am using two external buttons to scroll up and down through the presets. For the sake of argument, let's imagine I am only using one effect type, PolyPitch. I can have several presets with various settings saved, but for all of them the display will simply show "PolyPitch" and not my custom Preset Name. All the different sounds are indistingushable when labeled that way and the only way to navigate is to try them by ear. This is catastrophic and renders the unit useless for me... (I realize, that the list view is the intended way to do it, but with external footswitches it practically doubles the amount of clicks needed to operate the unit). It gets worse! To see the Preset Name at all I have to enter the list view by pressing both footswitches. Both footswitches are also needed to access the tuner. It is very easy for one footswitch to slip while holding both of them in order to access the tuner - the pedal will then either enter the list mode or activate a preset. I also wish there was a way to cue the presets with external footswitches from the single effect view. External footswitches would scrool through presets and the built-in ON footswitch would activate it. Those behaviours are native to other Helix products and as a seasoned HX Stomp user I can't wrap my head around this not being implemented in HX ONE, especially because of the small form factor. Best, Janko 2 1 Quote Link to comment Share on other sites More sharing options...
Reedner Posted January 2, 2024 Share Posted January 2, 2024 Couldn't agree more! I am having the same frustration. Thanks for posting this. Hopefully there will be a resolution or I am going to return the pedal. On 12/29/2023 at 4:17 PM, jankoraseta said: Please, please add a mode that will show the Preset Name instead of name of the effect. I am using two external buttons to scroll up and down through the presets. For the sake of argument, let's imagine I am only using one effect type, PolyPitch. I can have several presets with various settings saved, but for all of them the display will simply show "PolyPitch" and not my custom Preset Name. All the different sounds are indistingushable when labeled that way and the only way to navigate is to try them by ear. This is catastrophic and renders the unit useless for me... (I realize, that the list view is the intended way to do it, but with external footswitches it practically doubles the amount of clicks needed to operate the unit). It gets worse! To see the Preset Name at all I have to enter the list view by pressing both footswitches. Both footswitches are also needed to access the tuner. It is very easy for one footswitch to slip while holding both of them in order to access the tuner - the pedal will then either enter the list mode or activate a preset. I also wish there was a way to cue the presets with external footswitches from the single effect view. External footswitches would scrool through presets and the built-in ON footswitch would activate it. Those behaviours are native to other Helix products and as a seasoned HX Stomp user I can't wrap my head around this not being implemented in HX ONE, especially because of the small form factor. Best, Janko 1 1 Quote Link to comment Share on other sites More sharing options...
thomps72 Posted January 8, 2024 Share Posted January 8, 2024 Agreed! Please allow for external footswith to scroll preset names, then use the ON button to activate (load the preset rather than instant activation). This would be very very helpful. The HX Stomp displays the user named preset, why not the same for the HX One. Thank you. Quote Link to comment Share on other sites More sharing options...
datacommando Posted January 9, 2024 Share Posted January 9, 2024 On 1/8/2024 at 1:34 AM, thomps72 said: The HX Stomp displays the user named preset, why not the same for the HX One. Thank you. Hi, Surely this is covered in the HX One Owner’s Manual, page 10. ”Adding and editing effects is all well and good, but having presets with all your specific effect and other settings just a tap away can be a faster way to work! Your HX One comes loaded with numerous Factory Presets, which you can recall and use as they are, modify, or completely replace with your own creations (more about Saving presets in the next section). To access HX One’s 128 preset locations, enter Preset Mode.” Then it continues on page 11. Saving/Naming a Preset https://line6.com/data/6/0a020a3f12a29655656a3e05ee/application/pdf/HX One Owner's Manual - English .pdf Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
jankoraseta Posted January 10, 2024 Author Share Posted January 10, 2024 Thanks, sadly that is not the point. The Preset Mode is not really a “Mode”, but a scroll screen for preset selection and there are multiple issues with it, as described above. Best, Janko 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted January 10, 2024 Share Posted January 10, 2024 On 1/10/2024 at 12:02 PM, jankoraseta said: Thanks, sadly that is not the point. The Preset Mode is not really a “Mode”, but a scroll screen for preset selection and there are multiple issues with it, as described above. Best, Janko Hi, Janko, Ah, I see. In that case I must point out that there are no Line 6 staff here and only very occasionally do they visit these forums - (See the “sticky comment” in the black banner stripe at the top of this page entitled “Welcome to the Line 6 forums”). This link is where you need to go to have any hope of it been seen by anyone from Line 6: https://line6.ideascale.com/a/index Before posting any new ideas, please do a search to see if it's already been listed. Multiple requests for the same thing will thin out the votes. Also, post your ideas one at a time. Many users don’t vote for combined suggestions. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
jankoraseta Posted January 10, 2024 Author Share Posted January 10, 2024 Done, thanks! 1 Quote Link to comment Share on other sites More sharing options...
larsmaasboel Posted Wednesday at 08:55 PM Share Posted Wednesday at 08:55 PM Hi everybody. I had the same issue, here's the fix. Now I can see my own designated preset name in the display when I scroll up/down, both on the pedal itself, and with a two knob momentary switch.(ampero/hotone) To display custom preset names instead of the original effect model name on the HX Oneupdate your firmware to v3.80 or later and change the setting in Global > Display to "Preset". This allows the home view to show your custom names rather than the default model name. Here is how to configure it: Update Firmware: Ensure you are running firmware v3.80 or higher. Access Settings: Hold the Effect knob down for 1 second. Navigate: Use the left/right arrows to navigate to the Display setting. Change Display Setting: Set the display to Preset to permanently show the preset name, or Auto to show the model name for 3 seconds before switching to the preset name. Key Notes: Auto Mode: If set to Auto, the model name appears for 3 seconds after editing before reverting. Model Mode: Keeps the effect model name displayed. Functionality: This feature applies only to the HX One and was introduced to address the limitation of only showing effect names. Quote Link to comment Share on other sites More sharing options...
