stugatzo Posted January 16, 2024 Share Posted January 16, 2024 Hi all. Just got the new Boss IR-2 to add to my HX Effects board. For background, I know how to use command center and have successfuly used it to trigger MIDI changes and amp channel changes in the past. However, I have figured out through trial and error that that only signal the IR2 accepts from the HXFX to make it switch between the red and green (A/B) channels is a "momentary" pulse (as opposed to latching). So my question is this: Is it possible to program an instant 'momentary' command out of the HXFX via the ext footswitch ports when using snapshots? So when i switch from Snap1 to Snap2 (for example), it immediately triggers a mode change (red to green or green to red) on the IR2. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Schmalle Posted January 18, 2024 Share Posted January 18, 2024 On 1/16/2024 at 2:32 PM, stugatzo said: I have figured out through trial and error that that only signal the IR2 accepts from the HXFX to make it switch between the red and green (A/B) channels is a "momentary" pulse (as opposed to latching). Check again because the Boss manual indicates that the CH SEL input is for latching switches. Quote Link to comment Share on other sites More sharing options...
