mvenet Posted January 23, 2024 Share Posted January 23, 2024 My Pod Go had been successfully updated to latest version: 2.0.1. It states this on device boot up screen. However, POD Go edit software does not "see" it: IE on opening software I get prompt to upgrade firmware I just ignore prompt and everything still works fine. However confirmed that POD Go Edit is seeing old firmware as none of the "new" devices (amps or effects) are available in software. The new devices with 2.0 are all there and selectable in the POD Go itself. Any ideas? Thanks, Marc Quote Link to comment Share on other sites More sharing options...
usedbyanr Posted January 23, 2024 Share Posted January 23, 2024 Based on your explanation I would say that you upgraded the firmware through your current version of Pod Go Edit without installing the new version of Pod Go Edit. The update is a two part process. The full explanation is on the Pod Go Edit Software webpage or the Pod Go Firmware webpage. The image below from those pages sounds like your problem. Quote Link to comment Share on other sites More sharing options...
mvenet Posted January 25, 2024 Author Share Posted January 25, 2024 Correct. All set. Tx Quote Link to comment Share on other sites More sharing options...
