Toggle controller assignment off/on by engaging a different block/footswitch?
Mister4tee4
Greetings-
Apologies if this has been covered.  I couldn't find anything obvious.
I have a couple of stock reverbs in a preset with their "mix" controlled by the onboard expression pedal, which I also use to send into an internal volume pedal>long delay>reverb chain.  The "mix" of the stock reverbs decreases as the "send" to the ambient chain increases.  That's all cool...
However, I also have a wah assigned to FS 1 that also uses the onboard expression pedal.  I can effectively disengage the "send" to the ambient stuff when I engage the "wah," but I would also like the two stock reverbs that normally decrease in mix when I use the expression pedal to remain audible at their default mix setting while the wah is wah-ed...
Can I essentially toggle the controller parameters of the two stock reverb blocks off and on by using (FS1)?
Many thanks!
