PC+112/PC112 standard
mrbgtogo
With a Helix and two + models connecting Helix to PC+1 via AES and PC+1 to PC+2 via AES, yes.
Using one of each you would have the complete stereo signal into PC+ and that is the signal the standard would receive from the PC+ single XLR Out.
For stereo in your situation use the separate L/R outs from your unspecified modeler one to each PC input.
If you connect the PC+ via AES then you have full per preset configuration options on that, but in order to get stereo you'd need to pan that output block hard Left and use the Right 1/4" (or XLR) for the standard PC (left would collapse stereo to mono, so it wouldn't be true stereo).
Load up the attached example preset and examine the way the split is configured.
