peeweejd Posted February 23, 2024 Share Posted February 23, 2024 I have a POD Go and use it with an external pedal. Is there a power supply I can purchase that will power the POD Go and a couple pedals? I think I've seen some expensive power supplies, but I was hoping to use one that is similar to the brick we got, but has 2/3 outputs on it. I think I posted a question like this before but can't find it through search and there is no "profile" page I can find. Quote Link to comment Share on other sites More sharing options...
rarellano Posted February 26, 2024 Share Posted February 26, 2024 https://sweetfootpedals-com.3dcartstores.com/HX-Micro-1-2-Outlets--TINY_c_77.html 1 Quote Link to comment Share on other sites More sharing options...
peeweejd Posted February 27, 2024 Author Share Posted February 27, 2024 On 2/25/2024 at 9:29 PM, rarellano said: https://sweetfootpedals-com.3dcartstores.com/HX-Micro-1-2-Outlets--TINY_c_77.html Thanks for the suggestion. After a bit of chatting with John from Sweet Foot Pedals, I ordered a HX Mini (it has 4 outputs so I can add another couple pedals in the future). https://sweetfootpedals-com.3dcartstores.com/HX-Mini-Totally-Isolated-Power-Supply--APPROVED-BY-LINE-6--Handmade-USA-_p_569.html Quote Link to comment Share on other sites More sharing options...
peeweejd Posted March 6, 2024 Author Share Posted March 6, 2024 I thought I would share more information here. I ordered a power supply from Sweet Foot pedals and received it yesterday. As stated above, I ordered the "HX - Mini" https://sweetfootpedals-com.3dcartstores.com/HX-Mini-Totally-Isolated-Power-Supply--APPROVED-BY-LINE-6--Handmade-USA-_p_569.html The power supply feels like really good quality. The power supply uses a normal 110V input cable (he provides one) that you probably have some laying around the house. The power supply has 4 outputs; 1 output for the POD Go with high current, and 3 normal outputs. The white one is the one to use for the POD Go (or HX) and the black ones are for other pedals. He includes a special cable that has a normal connector for the power supply side and a special connector for the POD Go side. When it's plugged in you see a blue LED that lights up. I attached a couple photos showing it hooked up to my POD Go and a Digitech Drop pedal, and also a photo showing the input and outputs. Quote Link to comment Share on other sites More sharing options...
