jmdallett95 Posted February 23, 2024 Share Posted February 23, 2024 I’ve been failing miserably at trying to add an external tap tempo footswitch to my HX Stomp. It is a RockSound single non latching switch and I’ve followed instructions to assign it in both the Global and preferences menus. Wondering what I’m doing wrong. Here are some probably dumb questions: Do you need to remove the tap/tuner function from FS3 to do this? If I’m only running a single switch does that mean I should NOT use a TRS cable and just use a standard 1/4” patch cable? Do I need to run a Y splitter to separate FS4/FS5 input? The only results I saw when trying to do this was once or twice the tuner came up, but then I could not exit it via the footswitch. Thanks for the help guys Quote Link to comment Share on other sites More sharing options...
Schmalle Posted February 23, 2024 Share Posted February 23, 2024 TS cable is sufficient. Set Global Settings -> Preferences -> EXP/FS Tip to FS4 Global Settings -> Preferences -> EXP/FS Ring to EXP2 (to make sure FS5 doesn't get triggered by the TS plug) Global Settings -> Preferences -> Tip Polarity to Normal Global Settings -> Footswitches ->FS4 Function to TAP/Tempo Quote Link to comment Share on other sites More sharing options...
jmdallett95 Posted February 29, 2024 Author Share Posted February 29, 2024 @Schmalle, worked like a champ. Thanks for your help! 1 Quote Link to comment Share on other sites More sharing options...
