Detgyver Posted February 28, 2024 Share Posted February 28, 2024 Hi, I have a helix and I plan to buy a HX stomp for rehearsals. Is it possible to transfer a Setlist with all Presets to the HX Stomp? What restrictions are there? Greetings Detgyver Quote Link to comment Share on other sites More sharing options...
Justin65 Posted February 28, 2024 Share Posted February 28, 2024 Yes, it is possible to transfer a setlist with all presets from the Helix to the HX Stomp. Both Line 6 Helix and HX Stomp use the same HX Edit software for editing and managing presets and setlists, which makes transferring presets and setlists between them relatively straightforward. Here are the general steps to transfer a setlist with presets from the Helix to the HX Stomp: Connect Devices: Connect your Helix and HX Stomp to your computer using USB cables. Open HX Edit: Launch the HX Edit software on your computer. Make sure you have the latest version installed for compatibility. Backup Helix Setlist: In HX Edit, locate the setlist you want to transfer from the Helix. Right-click on the setlist and choose "Export Setlist" from the context menu. Save the setlist file to your computer. NCEdCloud Import Setlist to HX Stomp: With the HX Stomp connected and recognized in HX Edit, you can import the setlist file you exported from the Helix. In HX Edit, go to File > Import Setlist, then select the setlist file you saved earlier. Follow the prompts to import the setlist to the HX Stomp. Check Preset Compatibility: While the HX Stomp shares many features with the Helix, it has fewer footswitches and processing power. Ensure that the presets you transfer from the Helix to the HX Stomp are compatible with the smaller footprint and processing capabilities of the HX Stomp. You may need to make adjustments to fit within the limitations of the HX Stomp. Test and Adjust: Once the setlist is transferred, test each preset on the HX Stomp to ensure they sound as expected and make any necessary adjustments to optimize performance. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted February 28, 2024 Share Posted February 28, 2024 On 2/28/2024 at 9:55 AM, Detgyver said: Hi, I have a helix and I plan to buy a HX stomp for rehearsals. Is it possible to transfer a Setlist with all Presets to the HX Stomp? What restrictions are there? Greetings Detgyver Hi, This has been discussed previously in these threads - check this one. Short answer:- Remember HX Edit is capable of Multi-Device, Multi-Window Support, which will allow you to drag and drop presets between your 2 units. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
Detgyver Posted February 28, 2024 Author Share Posted February 28, 2024 Thanks for the fast Help! 1 Quote Link to comment Share on other sites More sharing options...
