Creating snapshots - I can't do it!
marianguitar
I would like to ask someone to help me with the following problem (I only have an English manual and I can't solve it somehow) - I will describe it on a specific simple example:
I want to set:
snapshots 1 Twin Harmony off *
snapshots 2 Twin Harmony ON and KEY on C scale on major *
snapshots 3 Twin Harmony ON and KEY on A, scale on minor *
snapshots 4 Twin Harmony ON and KEY on A, scale on minor harmonic *
Setting snapshots where Twin Harmony is ON/OFF will show, but as soon as I go to set KEY and SCALE to a different value, the last setting is still overwritten, where I make a mistake. Can someone tell me how to set the above settings to keep it in every snapshot?
Thank you marianguitar
Ahoj,
Chcel by som niekoho poprosiť, či by mi nepomohol s nasledujúcim problémom (mám len anglický manuál a neviem to nejako vyriešiť) - popíšem to na konkrétnom jednoduchom príklade:
Chcem nastaviť:
snapshots 1 Twin Harmony na off *
snapshots 2 Twin Harmony na on a KEY na C scale na major *
snapshots 3 Twin Harmony na on a KEY na A, scale na minor *
snapshots 4 Twin Harmony na on a KEY na A, scale na minor harmonic *
Nastavenie snapshots kde je Twin Harmony ON/OFF a prejavia, ale akonáhle idem nastavovať KEY a SCALE na inú hodnotu, tak sa mi stále prepisuje posledné nastavenie, kde robím chybu. Môže mi niekto napísať postup, ako nastaviť vyššie uvedené nastavenia, aby mi to v každom snapshote zostalo?
Ďakujem marianguitar
Make sure you have assigned the Key and Scale parameters to the Snapshot controller. To do this on the Helix device, quickly press and rotate the knob associated with those parameters. The values will appear in brackets when properly assigned.
