woodywyatt Posted March 23, 2024 Share Posted March 23, 2024 I'm trying to power my HX one with my Joyo 2 power bank but it only briefly powers on before turning back off again. Any ideas why? Or any recommendations for a new power bank that will work! Thanks! Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 23, 2024 Share Posted March 23, 2024 First, make sure your HX One behaves properly when used with the Line 6 power supply that came with it. That will rule out your HX One itself as the problem. Then check the specs on your Joyo and make sure they match the HX One - 9VDC, center-negative, 2.1mm center diameter, 500mA. If the specs match and it doesn’t work there’s likely a problem with your Joyo. 2 Quote Link to comment Share on other sites More sharing options...
woodywyatt Posted March 23, 2024 Author Share Posted March 23, 2024 Thanks for your swift reply. I think I've sussed it. There's only one slot (8th one) for 500mA. Seems to be working now. Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 23, 2024 Share Posted March 23, 2024 Glad you got it worked out. But perhaps you should be more cautious about connecting power to electronic devices. Sounds like you connected things together without checking compatibility or requirements. That can quickly and easily cause internal components to fry beyond repair. A crackling sound and whiff of smoke should not be the way you discover that things aren’t properly matched. 1 Quote Link to comment Share on other sites More sharing options...
