Kendall124 Posted March 24, 2024 Share Posted March 24, 2024 Good morning gang. I’m trying to set up a simple, wet/dry/wet rig. Guitar to Marshall, effects send on Marshall to front Helix input. 2 signal paths panned left and right. No amps or cab IR’s, just simple/common time based effects. L/R outputs from Helix to Seymour Duncan Powerstage 700. SD outs to cabs. Question. Can I use the “Guitar Thru” on the back of to the Helix to return of the Marshall? Will it be “dry”? I’m guessing my 2 “wet” paths will carry the Marshall’s preamp tone? I know I know…Try it!!! Waiting on the arrival of the SD. I’m struggling. 1) My Helix tones are amazing but I get buried in a live situation when there’s a 2nd guitar. I don’t/can’t run to FOH. 2) My Marshall tone is amazing but lacks the endless options of the Helix. Any help/experience will be welcome. Thanks! Quote Link to comment Share on other sites More sharing options...
Schmalle Posted March 24, 2024 Share Posted March 24, 2024 The dry through should work for your return. When you get burried in a mix that can have multiple causes. This might help: listen to your amp from another angle use appropriate volume often making your sound more mid-focused helps try to find a complementary sound that works with the 2nd guitar Quote Link to comment Share on other sites More sharing options...
