PC IR'S
mrbgtogo
METHOD 1
If the IRs are loaded on the Powercab:
In HX Edit, select the Output Block. In Bypass/Controller Assign select the Powercab tab.
REMOTE=Preset
MODE=User IR
SELECT 1=Using User IR Select the desired IR for the LEFT Speaker
SELECT 2=Using User IR Select the desired IR for the RIGHT Speaker
If you're changing IRs using Snapshots assign MODE, SELECT and User IR to Snapshots.
SAVE your Preset. If using Snapshots repeat for each Snapshot.
Use PC Edit to check that when the preset loads you get the expected result.
Then double check using your ears.
Sometimes L6 Link does not perform as expected using this method.
ALTERNATE METHOD:
Use your Path 2 Split to load separate IR Blocks.
At the MIX Block PAN A full LEFT and B full RIGHT. Make sure there's no MONO blocks after the MIX Block.
If using Snapshots, in the IR Blocks set IR Select to Snapshots.
Set the Powercabs to Preset 0 - Flat/FRFR (whatever it's called on the 112+, I have a 212+ which calls it Flat Stereo).
