Feature request - APP: Add a input volume padding for USB audio input
Wistee
THE SITUATION:
  • When I connect my iphone with usb and play a song from spotify or other, we LOOSE the colume control on iphone.
  • This is because as per apple guidelines, the UNIT ( the Catalyst amp) should take control of the volume. But there is NO input volume control on the amp, nor in the app. There are situations where my volume is at normal volume and if by bad luck I start a song or visit a page while being plugged the sound BLASTS through the speakers or headphones. Very dangerous
The problem:
The amp has no volume control for alt USB input
  • There is no control for the Audio USB input
  • And I could not find any in the app. Is there one?
The feature request:
Add a volume control in the app so we can reduce the input by X DB. Pad it down through a continuois controler.
This is a user-to-user support forum.
Nobody from L6 hangs out here.
If you want someone from L6 to see your suggestion, post it HERE:
https://line6.ideascale.com/c/
Search first and vote for all of the similar suggestions so as not to dilute the votes.
FWIW - while you're growing old waiting for L6 to implement your suggestion, get a cheap mixer, run the iPhone into it and connect the mixer to the AUX In.
