marmatkat Posted May 9, 2024 Share Posted May 9, 2024 Hi Folks. I use a Powercab 112 Plus for gigs with my Helix LT, and I carry an older Boss KATANA-50 as my backup in case the Helix fails. However, I'm thinking of buying a Mustang Micro headphone amp for practice, and I'm wondering if I could output that via its USB-C port to the Powercab as an emergency backup solution. I'm not clear on USB audio concepts, so I hope it's OK to ask here if this is possible (and if so, feasible for my application). Thanks! Quote Link to comment Share on other sites More sharing options...
rwandering Posted May 9, 2024 Share Posted May 9, 2024 I think no, because there is no USB host in this picture. Both the Mustang Micro and the PC+ are USB clients. Now, I may be wrong and the Mustang may also act as a host, but I'm skeptical. Alternatively, you might be able to run the headphone output through a 1/8" to 1/4" cable (as TS not TRS) to the back of the PC and turn the output up high . . . and then get something. But that input is balanced, not unbalanced, so I'm not sure what the outcome would be. (and if you use TRS to connect from a stereo output, you definitely get a bad outcome). A few variables here, and would it sound good? I doubt it. 1 Quote Link to comment Share on other sites More sharing options...
