Power Cab Plus DI out.
boblove1
I use a helix floor with a power cab + 112.  I generally use a modeled speaker cabinet from the helix and run the power cab in FRFR.
If I'm using the DI to the front of house or floor monitor, do I have the ability to select a microphone type for the DI out?  It doesn't seem like I should or would if the PC+ is FRFR.
I know, just go try it.....
The "MIC" feature in the Powercab is only applied when you're using Speaker Emulation.
FRFR just passes what comes in from the Helix. Same as if you just ran the XLR from Helix.
  • 1 month later...
