Treering Posted May 16, 2024 Share Posted May 16, 2024 I have an Ibanez 5-sting bass with an active EQ, plugged into my POD GO. That is plugged into my TC Electronic BQ500 amp (which also has an EQ). When I play at higher volumes I get a clipping sound like hard crackle, especially noticeable on the B string. How can I resolve this issue. I assume it has to do with too many EQs. Quote Link to comment Share on other sites More sharing options...
theElevators Posted May 16, 2024 Share Posted May 16, 2024 You could add a compressor to make the signal more even. Or you could simply try to cut the initial signal of the bass by using the volume pedal block--remove the assignment from the expression pedal, leave it static and simply lower the initial input signal by a few decibels. Quote Link to comment Share on other sites More sharing options...
