xee666 Posted May 27, 2024 Share Posted May 27, 2024 I'm new to Line 6 but decided to try the HX Effects because it looked like a simpler solution to what I've been doing. I spent all morning setting it up with the 4-cable method and got some great sounds, but my goal is to use it in stereo with the 7-cable method. I've got my two amps connected properly, I made an all-stereo pedal board, but I'm getting nothing out of my second amp. I just spent about an hour in the manual and the HX Edit software trying to find a way to make it work, but I'm stumped. What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
Schmalle Posted May 27, 2024 Share Posted May 27, 2024 The most likely causes that come to mind: output block panned hard left or right using right input for your guitar Quote Link to comment Share on other sites More sharing options...
xee666 Posted May 28, 2024 Author Share Posted May 28, 2024 I don't see an output block on HX Edit. I see where it says "Main L/R" at the end of my signal path, but I see no way to control that. Explain this to me like I'm five lol I have only used analog stomp boxes until this weekend. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted May 28, 2024 Share Posted May 28, 2024 On 5/28/2024 at 5:34 PM, xee666 said: I don't see an output block on HX Edit. I see where it says "Main L/R" at the end of my signal path, but I see no way to control that. Explain this to me like I'm five lol I have only used analog stomp boxes until this weekend. The Output Block is what you found at the end of the chain which says "Main L/R" . It has two parameters: Pan and Level. Make sure Pan is set to Center. 1 Quote Link to comment Share on other sites More sharing options...
