Using my old amp as a stage monitor
RikKempen
For a gig with 10-membered band, I want to use my old amp as a monitor on stage so I'll hear myself playing better when the stagemix isn't the best. I still want to use the output from my Helix LT for the audience and not the sound from my old amp, amplified with a mic.
So how should I set the preset on for that gig so that this becomes possible ?
Put a Send block in your preset before the cab/IR block and cable the Send output to the Return input on your amp. Consult your amp documentation to determine what level that input expects (instrument, line) and set the Level of your Helix Send output accordingly.
Note that any FX blocks after the cab/IR block in your preset will not be routed to your amp.
  • Upvote 3
