toko42 Posted May 30 Share Posted May 30 Is there a way to use both EXP1 and midi CC4 to control the main out volume? I found that I could program various parameters to be controlled by one of the footswitches as well as midi CC but not main volume. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted May 30 Share Posted May 30 No, unless you do the loop back trick: send expression pedal CC#4 data (Command Center) via MIDI OUT to the other MIDI controllers MIDI THROUGH so it comes back as external CC to Helix's MIDI IN. But: CC#1...CC#3 emulate the Expression pedals; can't you use these instead of CC#4? Quote Link to comment Share on other sites More sharing options...
toko42 Posted May 31 Author Share Posted May 31 That was obviously too straightforward for me but works fine. Thank you very much! 1 Quote Link to comment Share on other sites More sharing options...
