Pod Express Delay does not save with preset
dachilla
Hi there,
I did the firmware update for the pod express today (longtime HX user in all forms).
I tried to save presets with just a bit of delay and then went back and forth between presets. But then the amount of delay was much more than when I saved it. I tested that several times also with different amps or effects. Do I miss something?
Thanx
  • dachilla changed the title to Pod Express Delay does not save with preset
Did you perhaps change the tempo using the Tap footswitch? The Tap switch can be used during the Preset Select and Save operations so it’s possible you made an errant press at some point. Reread that section of the manual and try again. If it’s still not working then you will at least have eliminated a possibility.
So I tried it both ways Tap Tempo on global or preset. I save a preset with a small amount of analog or digital delay. I switched between presets up or down, when I come back to the saved preset the amount of delay has increased by a lot.
I also tried a factory reset, same result. I think Modulation and Reverb do not behave in the same way but delay definitly does. I also tried it with different amps.
It is getting some how very strange. If I just light up the first instance of the delay LED, go to save , listend to the preset, save the preset. Go presets up or down, come back, the sound might stay the same.
If I light up the sencond instance of the dealy LED, still first LED light, go to save , listend to the preset, save the preset. Go presets up or down, come back, the sound of the delay totally different .
So what do I do?
