Help with Command Center PC MIDI
AWF_Noone
Hello, there must be some sort of setting that I am missing, but could you help me with setting up MIDI with presets and snapshots?
What I would like to happen:
When I change patches, my stomp will send an instant PC command via command center to my other pedal
What currently happens:
When I change patches, the correct MIDI PC message is sent and the external pedal responds correctly, but the command center instant command is tied to snapshots, not the patch. So when I run through my snapshots, the same PC message is sent when I switch to snapshot 1. I would like my stomp to send the PC message only when I change patch. regardless of what snapshot I am in within the patch.
Any help would be appreciated!
The only way to do that is to use the "PC SEND" Global Setting, which sends the automatically assigned PC# when the preset loads.
Obviously, this is very limiting.
If you're not using all of your snapshots, create a duplicate of SS1 with the preferred (or no) PC# and use that instead of returning to SS1.
  • Upvote 2
