jpmpdt Posted June 10, 2024 Share Posted June 10, 2024 According to the manual, CC70 is "All Bypass". But is that analogous to Tap+Mode TRUE Bypass? Quote Link to comment Share on other sites More sharing options...
Schmalle Posted June 11, 2024 Share Posted June 11, 2024 It is the same as pressing Tap+Mode. But whether that is true (analog) bypass or DSP bypass depends on Global Settings -> Preferences -> Bypass Type. Tip: you can use HX Effects as a MIDI Controller using Command Center. With a MIDI cable connecting MIDI Out and MIDI In you can test stuff like this yourself. In this case set up a footswitch: Command = CC Toggle, MIDI Channel = Base, CC = 70. Dim = 0, Lit = 127. 1 Quote Link to comment Share on other sites More sharing options...
