HX Stomp Bass Guitar Preset Pack
beveridge16
The Bass-ic’s Preset Pack
The Bass-ic's preset pack is every utensil you would ever need in the studio or on the stage. From fat and clean to a saturated monstrosity, these presets have you covered. All of these presets were built with a passive, Fender style instrument in mind, but will work on most every bass!
Featured in this pack:
    •    "Hitsville" - A digital recreation of James Jamerson's signal flow. Get the iconic bass sounds from the infamous studio without any of the expensive and heavy vintage outboard gear.
-Saturation and warmth provided by tube preamp & tape reel emulation.
-FS1: Classic Opto style squash
-FS2: Low and High Cut to emulate the EQ of classic motown recordings
    •    "Studio DI" - A slightly saturated tone you will never want to turn off. Created with a 70s Neve 1073 in mind. Get that "direct to the desk" tone.
-FSI: Drive run in parallel to retain low end.
-FS2: Short Hall reverb
-Run these in conjunction to emulate a driven amp mic' d up in a room.
    •    "Short King" - Sculpted for all of you short scale enthusiasts out there. This tone will retain the fatness and thump of your bass, while keeping things tight and musical.
-FS1: Drive run in parallel to retain low end.
-FS2: A haunting reverb on a momentary switch. Great for reverb throws/ambient moments.
    •    "Amp Vault" - Choose between two classic amps running into a closely mic’d 1x15 cab.
-FS1: B - 15 (Clean)
-FS2: SVT(Dirty) + Short Hall verb (emulating room noise)
-Run these in conjunction to get even more grit!
** purchase link in YouTube description!
