Synthguitarist Posted June 22, 2024 Share Posted June 22, 2024 The expression pedal remains at 100% when rocked back and forth and the position setting does not change in the volume block or was block. The toe switch on/off is still functioning. Please advise. Thanks. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 26, 2024 Share Posted June 26, 2024 Operate the Toe Switch so that the Scribble Strip shows Exp 2 is selected. In HX Edit "Bypass/Controller Assign" Check that Both WAH and VOLUME are assigned to Toe Switch. Check that the WAH (name of wah) POSITION is set to Exp 1. Check that VOLUME POSITION is set to EXP 2. Manually (mouse) BYPASS the WAH block and ENABLE the VOLUME Block. SAVE the Preset. OR - delete both WAH and VOLUME blocks, SAVE, then re-insert them and those assignments should automatically be made. 1 Quote Link to comment Share on other sites More sharing options...
