michaelgqld Posted August 23, 2024 Share Posted August 23, 2024 I had an issue with license manager where it would not detect my hardware and I was unable to activate anything. I managed to solve this. I must also give credit to hurghanico for giving me an insight into what the issue was. Get the default.cfg file from this post. Place this file in C:\Users\yourusername\AppData\Roaming\Line 6\MonkeyCore\ Attached image of folder with file example. Doing this enabled me to activate my 500X, additional software packs and install them onto it. 1 Quote Link to comment Share on other sites More sharing options...
michaelgqld Posted August 23, 2024 Author Share Posted August 23, 2024 Trying this on a different laptop has not worked, so you may still have an issue. I will continue to look into it. Quote Link to comment Share on other sites More sharing options...
michaelgqld Posted August 23, 2024 Author Share Posted August 23, 2024 What I have found is the config file only supports Windows 10. The other laptop I tried is Windows 7. Manually editing the config file on that system to include Windows 7 in the 500X part of the hardware section allowed the Windows 7 laptop to to detect the 500X in License manager and in Monkey. I would use Line 6 central if you need to update your firmware however. So if you have Windows 10, I think it should work. Quote Link to comment Share on other sites More sharing options...
