Slandrieu8966 Posted August 29, 2024 Share Posted August 29, 2024 Has anyone played their Helix through a Vetta cab/speaker combo amp? Does it work well? Do you need to remove amp and speaker modeling in the Helix? Any successes? Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted August 29, 2024 Share Posted August 29, 2024 On 8/29/2024 at 8:47 AM, Slandrieu8966 said: Has anyone played their Helix through a Vetta cab/speaker combo amp? Does it work well? Do you need to remove amp and speaker modeling in the Helix? Any successes? Can it be done? Yes. Will you like the results? There's exactly one way to find out. Obviously the Vetta has it's own onboard amp models and effects...if you intend to use those, then my question is why bother with the Helix at all? But that's a whole other discussion. The Vetta has an FX loop I believe, so you also have the option of running in 4cm, which will allow you to use the amp models and FX in either unit. You could also just plug the Helix straight into the FX return, and only use the Vetta's power section. In that case you'd typically disable the Helix cab sims, though it's not "required". As is always the case with modelers, as long as you like the results you can do pretty much anything you want. Quote Link to comment Share on other sites More sharing options...
