albi70 Posted August 31 Share Posted August 31 I tried to use in my pod go the Ducked Delay, but it seems have some problem because even if I pump up the ducking I dont have "ducking effect". Quote Link to comment Share on other sites More sharing options...
grdGo33 Posted September 3 Share Posted September 3 "Pump up"? What did you pump? Probably pumped something which you shouldn't have pumped. Not all things should be pumped. Best bet would probably to put everything back to the middle, and just switch one thing at a time, that way you'll figure out what ever dial does! I'm guessing a high treshold or something prevents it from activating because it's too high! https://helixhelp.com/models?categoryId=5 Quote Ducked Delay Based on: TC Electronic® 2290 Available Parameters TempoSync1 Note Sync Time Feedback Low Cut High Cut Mix Level Threshold Ducking Dynamic Attack Dynamic Release Dynamic Type Trails Quote Link to comment Share on other sites More sharing options...
albi70 Posted September 5 Author Share Posted September 5 On 9/3/2024 at 8:13 PM, grdGo33 said: "Pump up"? What did you pump? Probably pumped something which you shouldn't have pumped. Not all things should be pumped. Best bet would probably to put everything back to the middle, and just switch one thing at a time, that way you'll figure out what ever dial does! I'm guessing a high treshold or something prevents it from activating because it's too high! https://helixhelp.com/models?categoryId=5 Ok, thanks Quote Link to comment Share on other sites More sharing options...
