I have two Spider IV (75 and 150) with the same signal path disruption
spydox
Oddly, both my Spider iv 75 and 150 have developed almost the exact same issue.
Play the guitar , and the sound is attenuated like 99%, even with volume up, but sometimes pops up to full volume when changing settings like to BLUES for example.  Full volume resumes for a second or two , then goes back to like 1% volume.
The input jack seems ok- moving it about doesn't change things.
Seems like the signal path is disrupted- some plug or cold solder joint perhaps? Seems like a mechanical issue not a chip fault. I did perform a factory reset. No difference.
Advice on self-diagnosis/repair is appreciated. I have a VTM, mini color o-scope, and signal generator and more on my bench.
Since two of my three Line 6 amps (the other is Spider V 240HC) have this issue , statistically, sounds like this is a probable fault that many many people have had.  I'm hoping that there are many methods to diagnose and fix it..
TY,
Eduardo
1-Double check your speaker cable. Make certain they are 8-Ohm speaker cable with 1/4" plugs and not guitar cables.
2-Make certain that the 8-Ohm speaker out is going to an 8-Ohm jack on the speaker or speaker cabinet.
Last time this issue showed up in our lab, it was one of those two reasons which are a result of impedance mis-match.
PS Im not seeing service centers close to 32905.
