Rockinthecat12 Posted September 11, 2024 Share Posted September 11, 2024 Hey Guys, Hello to all, I'm new to the forum. Just wondering, can the Catalyst speaker be shut off so I can record through the XLR out, and so I can monitor through my DAW. Thanks JS Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 11, 2024 Share Posted September 11, 2024 Turn the attenuator full counter-clockwise to the MUTE position. Keep in mind that XLR output volume is controlled by the CHANNEL Level, not the MASTER. If you want to use a custom IR Loader in your DAW you should load the Catalyst Edit program and in the speaker section, turn the speaker emulation OFF. This (or using other FX in your DAW) is really the only time you'd want to monitor through your DAW, as doing that adds latency to the signal. Quote Link to comment Share on other sites More sharing options...
Rockinthecat12 Posted September 12, 2024 Author Share Posted September 12, 2024 Thanks so much for the info, it's a big help Best Regards Quote Link to comment Share on other sites More sharing options...
