DarkMinion666 Posted September 16, 2024 Share Posted September 16, 2024 Hello everyone! I´m a bit deperate now. I checked lots of videos and posts here to get the connection problem solved, but nothing seemed to help. I´m a Helix user from the beginning. I bought my unit shortly after the release and I never updated it so far. So the Firmware must be one of the first ones. From HX I only get the message "connection interrupted". The reconnection button doesn´t help and when I unplug and replug the USB cable I get a Windows blue screen half of the times. I re-installed the software, tried several USB-cables, used all different ports on my PC, but nothing made a difference. I didn´t try the factory reset so far. I have 7 or 8 years of presets there, which I don´t want to delete. Writing all presets down by hand would take weeks, I guess.... Does anybody have an idea, how to solve this problem? Any help is appreciated! Best, Mike Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 18, 2024 Share Posted September 18, 2024 The BSOD in Windows indicates a computer issue. Start there. Make sure you've got the PC fully updated and running properly under the latest version of Windows. I haven't suffered a BSOD since Win10. Do a thorough memory integrity check, as the BSOD is often caused by bad physical memory. If you get it fixed, remember computers 101 - back up early, back up often! 1 Quote Link to comment Share on other sites More sharing options...
somebodyelse Posted September 19, 2024 Share Posted September 19, 2024 Hmm? THE only time I had a BSOD on W10 was the first time I ran the Line 6 updater when I got my Helix... my first 'rookie error' - should have used HX Edit, not L6 Updater. If I were you, first thing I'd do is plug the Helix in to another computer - laptop if you have one - install HX Edit (latest version + drivers) on that and get me a backup done. This will also help determine if the PC or the Helix/cable is knackered - might be neither... Once that's done, and I got to the bottom of the PC issue (if that was the case), I'd be inclined to update the Helix, but that one's your choice. Quote Link to comment Share on other sites More sharing options...
