tupamaros75 Posted September 29 Share Posted September 29 Im tryng to assemble my new pedalboard with Ik Tonex Pedal first and then Line 6 HX FX .....when I connect HX FX there's a lot of volume loss. When I put HX in bypass it's a little better, but far to the sound out from the Tonex. I've already check in)out line/instrument settings, still half volume and attack instead the Tonex output. I've used line HX FX since 2 years with real amps (connect in series, direct in input) and I never heard that signal loss. Is it normal? Quote Link to comment Share on other sites More sharing options...
Schmalle Posted September 30 Share Posted September 30 If the HX FX is off it is in analog bypass aka true bypass. There should be no volume loss if you connect Tonex -> HX FX (off) -> amp / mixer. Quote Link to comment Share on other sites More sharing options...
