HX Stomp Stereo/Dual Chain Question
koozoop
Good evening,
I'm planning to buy a multi effect to use with my stereo bass guitar (Billy Sheehan copy bass with stereo outputs). So, my question is if either the HX Stomp or Stomp XL can be used in such configuration, i.e. stereo in - stereo out to two amplifiers, assigning to each channel its own effects.
Thank you in advance for any help!
Yes. Both have stereo Ins and outs. However, you are limited to 8 FX total, and which ones you'll be able to use depends on the DSP load of the FX.
For example, if you're planning on using separate HX amps, which are MONO and DSP heavy, you might be VERY limited in the # of FX that you can use.
