Benlop17 Posted Saturday at 09:03 PM Share Posted Saturday at 09:03 PM Hi, I bought two days ago an Hx one, and I have been having a major hum while using it with a tube amp. It is a Carvin Vintage 16. Never had any problems with other pedals... Doesn't seem to do it with my Dv mark little jazz or a bigger transistor amp. Anyone has experienced the same issue ? thanks ! Quote Link to comment Share on other sites More sharing options...
benriddell Posted 22 hours ago Share Posted 22 hours ago The Carvin is a tube amp, correct; and are you powering the amp and the HX One from the same outlet? You might have a ground loop if you're running them from separate outlets (might being the main word) When I had pedals on a board (BOSS, EHX etc) and a Marshall half stack before going digital some of the pedals didn't play nicely with the amp, especially in the effects loop. I don't remember it being an issue with the Fender solid state amp I had before the Marshall. You might need a hum eliminator/ground loop isolator box between your HX One and amp Search "hum eliminator box" or "ground loop isolator box". They're in the sub £/€/$ 50 price range Quote Link to comment Share on other sites More sharing options...
