EpOxY81 Posted October 17, 2024 Share Posted October 17, 2024 I have an X3 Live that I've been using off and on for a while and the power supply is getting pretty worn down and I'm thinking about replacing it. I've been googling a lot and I see some replacement power supplies, but I haven't seen any information about the inputs required (specifically the mah needed). If I can, I'd like to get a multi-power supply instead of just replacing the power-brick, but I want to make sure I get one that can put out the necessary juice. Does it really need the 2000mah that the OEM supply puts out? Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 18, 2024 Share Posted October 18, 2024 On 10/17/2024 at 3:30 PM, EpOxY81 said: …. If I can, I'd like to get a multi-power supply instead of just replacing the power-brick, but I want to make sure I get one that can put out the necessary juice. Does it really need the 2000mah that the OEM supply puts out? I think it’s unwise to intentionally use any power supply that delivers a lower-than-specified number of milliamps (assuming that’s what you mean by mah). You’ll be inviting problems using anything else. Quote Link to comment Share on other sites More sharing options...
