Zoophagy Posted October 19 Share Posted October 19 I have an Audient audio interface plugged into my pc and I run studio monitors into the interface how would I go about hooking up the pod go so I can hear it through the monitors? Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 19 Share Posted October 19 Two ways depending on whether or not you want/need to continue to use your Audient audio interface for recording: 1) Remove the Audient from your configuration. Connect your monitors directly to the POD Go outputs. Connect you POD Go via usb to your computer and configure your computer and DAW to use the Pod Go as its audio device. This will give you more flexibility in recording tracks in your DAW, e.g. recording dry and processed tracks independently and simultaneously. It will also allow you to simply play without needing other devices powered on (your computer and the Audient). 2) Connect the POD Go main audio outputs to your Audient inputs and continue with everything else as is. You will only be able to record the POD Go’s main outputs. Quote Link to comment Share on other sites More sharing options...
