Can Helix Floor foot switches toggle between snapshots
GotMetalBoy
Can Helix Floor foot switches toggle between snapshots?
I want to be able to press fs8 to select snapshot 1 and then press fs8 again to select snapshot 2 and if pressed again it goes back to snapshot 1. I want it to work like a real amp channel switcher to toggle between my distorted snapshot 1 and clean snapshot 2.
If this is possible I'd like to also be able to setup fs9 to toggle from snapshot 2 to 1, fs10 from 3 to 1 and fs11 from 4 to 1.
I like being able to toggle quickly between my main snapshot 1 and other snapshots by only pressing one fs and not having to tap dance between fs.
I was able to do this with my old rig which was a Fractal Audio Systems Axe-Fx II XL+ and I can't remember if it was built into the Axe-Fx or I programmed it on my MIDI foot controller which was either my FAMC Liquid Foot+ (LF+) or RJM Mastermind GT22.
Yes!  in Command Center.  You can assign what each button can do.  And then after selection of a particular snapshot, you can assign what each button will do AFTER that snapshot is selected.  So you can have one button cycle through as many snapshots as you need.
This is a great feature for a smaller device..  But on the full Helix, I like to have each button be exactly its own dedicated snapshot, personally.  I don't want to accidentally double-press and get the wrong sound.  So here you go!
  • Upvote 2
