BCT777 Posted November 11, 2024 Share Posted November 11, 2024 I would like to set my system up so that I have the guitar going through an EQ into the HX. The signal then immediately goes out and in the effects loop going through some external overdrives and preamps that are MIDI controlled. Then it goes through the onboard effects and then the wet signal goes to the stereo outputs to a left and right Boss Katana 100 Mk2 head and 212 cabinet. I would like to take the dry signal from the preamps and route it from the HX to a center amp which is a Marshall JCM800. Is there a way to set up the second effects loop so it sends that dry signal out but doesn't interrupt the entire signal chain if there is nothing coming into the return? Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 11, 2024 Share Posted November 11, 2024 In the forums it’s included in the Helix area. I’ve moved your thread there. Quote Link to comment Share on other sites More sharing options...
