FelixKrohn Posted November 16, 2024 Share Posted November 16, 2024 Hey there, I need some volume control with the HX effects but just can't manage to get it to work. We have a couple of songs where I switch between finger play and slap. Slapping is much louder, so I want to have a volume control in my chai that I could make use of. So I thought of inserting a volume switch in my bank that I can switch during play. However, when inserting a volume switch in HX Edit, it doesn't show up in my HX effects. Next thought was going with Snapshots, but whatever I program in my 2nd snapshot for the respective preset just mirrors to the first one. Means: When inserting a volume to the 2nd snapshot, it also appears in the first one. Can anyone help me getting a workaround? Quote Link to comment Share on other sites More sharing options...
somebodyelse Posted November 18, 2024 Share Posted November 18, 2024 On 11/16/2024 at 6:24 PM, FelixKrohn said: Hey there, I need some volume control with the HX effects but just can't manage to get it to work. We have a couple of songs where I switch between finger play and slap. Slapping is much louder, so I want to have a volume control in my chai that I could make use of. So I thought of inserting a volume switch in my bank that I can switch during play. However, when inserting a volume switch in HX Edit, it doesn't show up in my HX effects. Next thought was going with Snapshots, but whatever I program in my 2nd snapshot for the respective preset just mirrors to the first one. Means: When inserting a volume to the 2nd snapshot, it also appears in the first one. Can anyone help me getting a workaround? Any setting you want to change for a Snapshot needs to be 'activated'. In HX Edit, with the Helix, you'd right click that setting and click Snapshot in the drop down menu. Then go to your (2nd) Snapshot and adjust that parameter. Tip of the day: Read the manual. This stuff is in there. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted November 18, 2024 Share Posted November 18, 2024 On 11/16/2024 at 7:24 PM, FelixKrohn said: Hey there, I need some volume control with the HX effects but just can't manage to get it to work. We have a couple of songs where I switch between finger play and slap. Slapping is much louder, so I want to have a volume control in my chai that I could make use of. So I thought of inserting a volume switch in my bank that I can switch during play. However, when inserting a volume switch in HX Edit, it doesn't show up in my HX effects. Next thought was going with Snapshots, but whatever I program in my 2nd snapshot for the respective preset just mirrors to the first one. Means: When inserting a volume to the 2nd snapshot, it also appears in the first one. Can anyone help me getting a workaround? By "volume switch" you mean Volume Pedal block? That should work. A Gain block also does the job. You can also controller assign a footswitch to control the Output block's Level parameter. You don't need snapshots for this. Quote Link to comment Share on other sites More sharing options...
BrentonAllen Posted November 21, 2024 Share Posted November 21, 2024 On 11/18/2024 at 5:33 PM, Schmalle said: By "volume switch" you mean Volume Pedal block? That should work. A Gain block also does the job. You can also controller assign a footswitch to control the Output block's Level parameter. You don't need snapshots for this. I love experimenting with different setups, and the HX Effects volume control topic caught my attention. Balancing sound dynamics reminds me of the thrill of gambling, fine-tuning strategies for the best outcomes. If you're into gambling like me, you might find https://nongamstopbetting.info/ helpful, check out nongamstopbetting.info for flexible and varied platforms. Just like getting the perfect tone with HX Effects, it’s all about customizing your experience. Thanks for the tips shared here; they’re super helpful! Thanks for the info, I will keep it in mind. Quote Link to comment Share on other sites More sharing options...
