therealmattfinn Posted November 23, 2024 Share Posted November 23, 2024 Ok, I have searched but not seen this as a topic, so I am wondering if I am doing something that I either shouldn't or just hasn't been done. I want to use my Helix LT and my Blackstar ID:Core 40 amp together. I want to use the FX loop to put the amp in the middle of my FX chain and then go direct to FOH from the Helix. I like the sound of my Blackstar, it just suits my playing etc. But I want the effects from my Helix and even if I come out of the amp, I would only be using the emulated line out (it has cab sims etc in it). So my question is, will it work if I put it in the effects loop or am I just being crazy. Looking forward to the range of answers I will receive! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted November 23, 2024 Share Posted November 23, 2024 Looking at the "Handbook" it appears that you would need to run a MONO SEND (set to INSTRUMENT level in GLOBAL SETTINGS>INS/OUTS) from Helix to the amp's guitar input with the THRU parameter set to -120db (OFF), then use a stereo cable from the CAB RIG/HP OUT to a pair of Helix RETURNS (Stereo RETURN Block, LINE/INSTRUMENT Level? Try both). To use the amp's speakers, you'd run a stereo cable from Helix L/R Main Outs (set to LINE) to the amp's LINE IN. You may need a special adapter to accommodate the 1/8" TRRS to the dual 1/4" needed for the Helix Outs. Use the Helix XLR Outs (set to MIC) for FOH. Quote Link to comment Share on other sites More sharing options...
