Delay times larger than 2000ms?
seamusgood
Not possible if the GUI doesn't let you...  You could try to export the patch, change the value and re-import, and there's a possibility it could work, also a possibility it wouldn't and might even cause issues so how bad do you want it?
Otherwise, I think you could stack delays?  If your 1st delay is 2s, configuring a 2nd delay with also 2s would extend the 1st one by that much, although you'll likely have to play a bit with the volume of the 2nd to get it to match the natural decal of the 1st reverb.
