guitar_player7 Posted December 2, 2024 Share Posted December 2, 2024 Hello everyone, I turned off my PodGo during a firmware update and now I'm stuck on the red/black intro screen. Tried holding down the C and D buttons while powering on but my unit won't move past the "Will reset globals, IR, etc" message. Is there any way to recover? Any help is appreciated. Thank you. Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 2, 2024 Share Posted December 2, 2024 If these don’t help you should open a support ticket. Quote Link to comment Share on other sites More sharing options...
guitar_player7 Posted December 2, 2024 Author Share Posted December 2, 2024 Thank you for reply. I appreciate your help. I tried both options but, unfortunately, I'm still stuck. I'll open a support ticket. Thanks again. Quote Link to comment Share on other sites More sharing options...
somebodyelse Posted December 4, 2024 Share Posted December 4, 2024 On 12/2/2024 at 4:43 PM, guitar_player7 said: Hello everyone, I turned off my PodGo during a firmware update and now I'm stuck on the red/black intro screen. Tried holding down the C and D buttons while powering on but my unit won't move past the "Will reset globals, IR, etc" message. Is there any way to recover? Any help is appreciated. Thank you. This will fix it - Download the latest versions of the POD Go firmware, Line 6 Updater and POD Go Edit. Start your POD Go whilst holding down the 'Page Right' button. Don't worry about the grey screen. Make sure your computer is not running ANY background music streaming crap like Spotify. Make sure your USB cable is in good nick. Plug the POD Go to your computer. Start Line 6 Updater in Offline Mode'. Select POD Go, select 'Update from file' and try re-installing the v2.0 firmware that you downloaded. If it fails to install, download any previous firmware version and repeat the above. When that installs successfully, close the updater, Switch off the POD Go and do the 'Factory reset' startup procedure. Plug the POD Go in, start up POD Go Edit - NOT the Line 6 Updater. FOLLOW THE INSTRUCTIONS. The update will take about half an hour. Quote Link to comment Share on other sites More sharing options...
slamdunkin Posted May 22 Share Posted May 22 I am having the same problems and when I go to do these steps my computer will not let my download Line 6 Updater because it says the download has malware or viruses. Please advise. Quote Link to comment Share on other sites More sharing options...
Tbonetuna Posted Thursday at 07:39 PM Share Posted Thursday at 07:39 PM the above response was 100% accurate- it worked! Thank you! One thing to also be aware of is there is "Line 6 Central" that you can download that will allow you to update the software. I've been told that sometimes updating through POD Edit can get messed up. If you are taking a big jump between firmware versions, consider doing it in steps. I went from 1.4 to 2.0, then to 2.5. It wouldn't work when I tried to go from 1.4 to 2.5. Good luck all! Quote Link to comment Share on other sites More sharing options...
