Resizing Window - accessing lower right corner
msalada
I cannot access the lower right corner of the Helix Native window in pro tools in order to try to resize the window.  The bottom of the window is below my viewable screen, and I can only raise it so far -- not enough to see the bottom of the window.  How can I resize the window?
First off, just so you know, I’m a Mac user and ditched ProTools many, many years back.
Having said that, when seeking assistance from Forum users it's a really good idea to supply as much information as possible regarding the computer and operating system version and the version of HX Native.
Anyhow, a couple of things spring to mind. One - IIRC, there is the option to "Override High DPI Scaling" somewhere in the PT preferences. You could try turning that off or, secondly, go to you computer display settings and check that it is not set to something higher than 100%. Try different screen size options.
That’s about all I have to suggest on this one. Maybe someone else can chime in with an idea.
Hope this helps/makes sense.
