axe1174 Posted December 16, 2024 Share Posted December 16, 2024 I am new to the Helix and play at home so i use small amps. I have a Peavey 6505 MH and an EVH Stealth LBX. I watched and did the connections to the Helix/Amp per 4 cable method Line 6 video. I then selected to 4 cable method under the templates per the video. I assume under this format you are supposed to use the pre amp presets as this is what the helix is set up to do. The video then says i can engage or disengage the footswitch for the loop to use my physical amp or the models. When i disengage the switch my amp is only a clean tone and none of the panel controls do anything. What am i missing here because its really frustrating Quote Link to comment Share on other sites More sharing options...
rd2rk Posted December 16, 2024 Share Posted December 16, 2024 Step 1 - open HX Edit and check (? icon>ABOUT) to see that Helix is on v3.80 and HX Edit is v3.82. Step 2 - check that your physical wiring is like this (all shielded TS cables): Guitar>Helix Input>Helix Send 1>Amp Input>Amp Send>Helix Return1>Helix L/Mono Output>Amp Return Step 3 - Load the attached example preset. FS2 should toggle between the Helix amp and your physical amp. 4cm.hlx 1 Quote Link to comment Share on other sites More sharing options...
