deluxe5594 Posted December 28, 2024 Share Posted December 28, 2024 Hello All, The Encoder 3 on my Helix LT is not working anymore. It goes only between 2 adjacent values. I don t know since what firmwareupdate this is happen but I guess a firmwareupdate is the reason for. I actually use 3.80. The Test UI says 128-129 only for encoder 3. Changing parameters with HX Edit is possible. They are transmitted to the Helix with in HX Edit choosen settings. But again, with encoder 3 only 2 adjacent values between the "new" settings on the Helix LT are possible. I opened a ticket to Line 6 support and they recommend to reset with button 9/10 etc. It doesn ´t help. Is this happen in a similar case to anyone else? Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted December 28, 2024 Share Posted December 28, 2024 Wellknown issue (never had it on my Floor back then but often on the Stomp). Defenitely seems to be software related - but it's never been truly fixed. And no, resetting doesn't help. Not good. Quote Link to comment Share on other sites More sharing options...
deluxe5594 Posted December 29, 2024 Author Share Posted December 29, 2024 Hi Sascha, Thank you for your reply. I updated my ticket 47989 to Line6 support now. The existing error makes it impossible to continue using the device. If Line6 will not find a solution I m done with them and do a change to Fractal. I will keep you updated. Greetings from "Germoney" too. Quote Link to comment Share on other sites More sharing options...
hurghanico Posted December 29, 2024 Share Posted December 29, 2024 Rotary Encoder for HX Stomp / Helix - FOUND! 1 1 Quote Link to comment Share on other sites More sharing options...
