J840 Posted January 7, 2025 Share Posted January 7, 2025 Is there a way to see the name of the snapshot in the display when in stomp mode? Currently it shows the preset and the snap number. If I scroll through the 8 snapshots with the bank buttons, just getting the number instead of the name is a bit tricky. The snapshots are named when I go to Snap mode. Quote Link to comment Share on other sites More sharing options...
datacommando Posted January 7, 2025 Share Posted January 7, 2025 On 1/7/2025 at 10:22 PM, J840 said: The snapshots are named when I go to Snap mode. Hi, Yup! - That’s the way it works - you can see the named Snapshots in Snapshot mode, and the Stomp names in Stomp mode. Bit of a clue in the mode name. You do have the option to have 4 Stomps displayed on the top row with 4 Snaps on the row below, or vice versa - 4 Snaps above 4 Stomps below. See Helix LT 3.80 Owner’s Manual > Page 54 > Arranging Preset, Snapshot, and Stomp Switches. https://line6.com/data/6/0a00051afd86673ccb96424d9/application/pdf/Helix LT 3.80 Owner's Manual - English .pdf Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
J840 Posted January 8, 2025 Author Share Posted January 8, 2025 Yes, I know about the 4 snap/stomp combos. I'm doing a one man band looper thing, so I have more than 4 snapshots that I go to frequently. I suppose maybe someday I can "sacrifice" and work with less... But having a Helix is a "more is more" item! I was just checking since there is all that empty space, maybe the snapshot name could fit in there. The preset name doesn't do me much good personally but I will survive. I can post that on ideascale I suppose. Does the Helix Floor handle this differently? I know it has the option for 10 stomps, LT has 8. Quote Link to comment Share on other sites More sharing options...
datacommando Posted January 8, 2025 Share Posted January 8, 2025 On 1/8/2025 at 3:01 AM, J840 said: Yes, I know about the 4 snap/stomp combos. I'm doing a one man band looper thing, so I have more than 4 snapshots that I go to frequently. I suppose maybe someday I can "sacrifice" and work with less... But having a Helix is a "more is more" item! I was just checking since there is all that empty space, maybe the snapshot name could fit in there. The preset name doesn't do me much good personally but I will survive. I can post that on ideascale I suppose. Does the Helix Floor handle this differently? I know it has the option for 10 stomps, LT has 8. Hi, I saw that you had posted on IdeaScale, but I seem to recall that someone else requested a similar thing way back. That never happened, so I wouldn’t hold my breath waiting for this, especially as the Helix is rapidly approaching it’s tenth birthday. Also - No, the Helix Floor doesn’t handle this differently, it doesn’t even have the Performance View like the LT, it uses Scribble Strips. Anyhow, regarding the Snapshot situation, have you investigated using the Command Centre which can greatly expand your options for working. Not so much with any greater on screen info, but the ability to stack snapshots on one switch and/or essentially create presets within presets. You might be able to find another way to navigate through your one man band gigs. Have a look at this video from Steve Sterlacci - he has a few covering this subject. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
